a "takes a strong leg" kickstart-only '68... what can be done?
on a 1968 IronHead XLCH that's been rebuilt, but has a hard-to-start kickstart in that it takes a strong leg -and- you have to get it just right, what can be done?
is that normal?
can something be adjusted or changed to make it easier to start?
can an electric start be added?
or is that a fact of life with one of those models?
thanks.
is that normal?
thanks.
I give my 75 two shots of gas with the throttle, close the choke, turn the idle speed screw in a half turn, give three prime kicks (ignition off), open the choke, turn on ignition and it will almost always start on the first kick.
When the engine is warm, it will usually start on the first kick, without doing anything else. I say usually, occaisionally it will pop once and then I will give it a few more kicks without doing anything else and it will start. A couple times after five or six kicks and no start, I've had to give it a little squirt of gas from the throttle and then she took off.
They're all a little different, but generally speaking, if it was a stock bike and in good shape, properly tuned, it should work about like that. If it doesn't, it needs work.
Two kicks with the key off and third with it on. More priming for colder starts, less for warmer. Get her to the compression stroke. Right knee on the seat, left on kicker, take you weight of the seat and transfer it to the kicker. A little throttle when you come down on her gently. Gee whiz I miss this.
Welcome from Freindly Manitoba
Mag or distributor? Points clean? Hows your timing?
also put FL round top caps on rear shocks for no bruising.
