primary drainplug oring
Bumping this old thread. Haven't changed the oil on mine yet, so don't know what o-rings and gaskets are used. But I just got some parts from J&P, and I got the 5/8" coppergaskets, but now I'm starting to wonder if it's the wrong gasket?
Is this gonna fit, or do I have to get some rubber o-rings?
http://www.jpcycles.com/product/740-380
Did you read the manual?
Some bikes have aluminum crush washers on the drain plug. My Kawasaki has one; the Sportster does not use a washer. It uses an o-ring that fits in a grove around the bolt. A new o-ring from HD is $0.99
- Don't forget the Teflon paste.
- Don't forget to clean the magnet of your gear teeth
- Don't forget the torque wrench
soft 02
08-31-2012 11:05 AM
