Too young to start marking it's spot!
Old 06-08-2011, 12:30 AM
Nubz's Avatar
Nubz
Nubz is offline
sorry that it isn't sealed for life and gaskets wear out lol
Old 06-08-2011, 05:45 PM
AaronG87's Avatar
AaronG87
AaronG87 is offline
It's an engine it leaks, **** breaks get over it's a little oil. Replace the gaskets, torque the head bolts to the proper amount and ride. Any engine will seep and leak even if it only has a few thousand miles especially if it sits there more than you ride.
Old 06-08-2011, 06:16 PM
Captain Chaos's Avatar
Captain Chaos
Captain Chaos is offline
Wrong, not every bike leaks oil. I've had and seen plenty of bikes (MUCH older and with FAR more miles than the OP's) that didn't leak a drop. Excusing stuff like this because it's "normal" or "it's a Harley, just get used to it" is just ignorant.
To the OP:
You have every right to be upset but no need to worry. I would expect ZERO problems (including leaks) from bikes as new as yours and I would be ticked at an oil leak on a 3yr old bike. Don't stress over it though as in order for it to leak enough to actually cause a real problem it would have to be POURING out. Just check your oil level from time to time as add as needed until you can get the gasket replaced.
Apparently rocker box leaking is a somewhat common problem. I never personally had any leaks on mine but others have. Just replace the gasket and hope it holds, that's all you can do. If it doesn't work and you're not willing to put up with an oil leaking bike, there are LOT's of great bikes out there to be had.
Also, the Synthetic oil has absolutely NOTHING to do with the leak. Synthetic oil causing leaks is an old wives tale that that has somehow managed to survive despite millions of riders who have proven otherwise.
Old 06-08-2011, 06:29 PM
ItsTomFromNorthJersey's Avatar
ItsTomFromNorthJersey is offline
:i con_hunter::icon_fla methrow:
cry baby, yea i agree go buy a jap bike and be the typical yupi.
Old 06-08-2011, 07:01 PM
wilburz's Avatar
wilburz
wilburz is offline
there is a good write up with pics in the how to section. Give it a try. I changed my rear one using that as a guide. Not to bad to do. 2 wrenches out of 5.
Old 06-08-2011, 07:08 PM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
Mine can leak all it wants to! I love wrenching on it just as much as I love riding on it.
Now if I could just find that 5mm allen wrench....
Old 06-09-2011, 06:12 AM
Terp84Alum's Avatar
Terp84Alum
Terp84Alum is offline
My 02 never leaked. I'm not sure why people are telling you it's ok or not a problem. Get it fixed or fix it yourself. If it leaks again, something is warped and that may be a bigger problem.
Old 06-09-2011, 07:54 AM
Chestyv32's Avatar
Chestyv32
Chestyv32 is offline
3rd Gear
If its not leaking something somewhere, Its not a Harley !!!!!!! Buying an import bike is like a Tampon, every Pu$$ys got one
Old 06-09-2011, 08:00 AM
ogh11756's Avatar
ogh11756
ogh11756 is offline
So common that a search would have found many posts on the issue.
Had mine done at 7200 miles, fine now.
Indy did the work for around $150.
Relax, its just a gasket job.
I assume you bought a Harley because you wanted a Harley.
Old 06-09-2011, 10:33 AM
UKLiz's Avatar
UKLiz
UKLiz is offline
You think you have it bad! Mine leaked from new. Day 1 (10 miles) splashes on boots. Day 3 (20 miles) splashed all over engine!
Dealer was great though and it seems OK now - fingers crossed.
Quick Reply: Too young to start marking it's spot!
