Swapping fuel tank
If you're swapping from 3.3 gal (peanut tank) to 4.5 gal tank, you will need the EFI green gasket part number:75301-07.
This will replace the old gasket between the tank and EFI module. Other than that you should be able to reuse the same tank hardware
(nuts and bolts).
I recommend emptying your tank completely prior to removal. (I used the siphon method) Good Luck and let us know how it went.
(nuts and bolts).
wydopn231
04-03-2008 01:19 AM
