removing vance and hines heat shields
I own a 2009 nightster. It came with vance and hines short shots with black heat shields . I'm trying to remove the heatshields but having problems accessing the clamps and I'm wondering if the shields will come off if i can get all the clamps loose??? It almost looks as if i have to remove the pipes ??? I'm new to the forum so I'm hoping someone outthere has some experience and can help me. Thanks for any help!!!
+1, the black scratches easily. I took mine off and put the heat wrap on. Then I put them back on and they're pretty scratched up just from laying around. The shields are held on with simple metal clamps. Don't use a screw driver, use a socket wrench it's easier. You may have to try to loosen it a touch and work it into a more accessible position. You definitely don't need to take the pipes off, and it's not hard, just a little frustrating and hard to do without scratching things up.
Whipped my shields of this morning, V & H Big Radius on a 2010 Nightster, took all of 10 minutes - 3 jubilee clips on the top pipe and 4 on the lower. I had to be a bit careful on the lower pipe when removing it as the brake pedal is very close. The jubilee clips had to be opened right up to remove the heat shields as they run under a retaining channel inside the shield.
I agree that a socket is the tool for the job here as a screwy can easily slip...
From memory, there's a total of 8 clamps. The clamps will stay with the heat shields when you pull them off.
jordanball33
01-28-2009 09:34 PM
