Ok Tuning geeks...Yer opinion..?
Guest
Posts: n/a
Actually, the ECM will compensate for aftermarket components. According to Stephen Mullens (remember, he has a product to sell as the owner of Nightrider), you absolutely, 100% do NOT need any type of aftermarket tuner or download, or anything else to safely run aftermarket exhaust and intake. His product, by his own admission, is to satisfy a need that is perceived, but doesn't actually exist.
People just don't seem to understand the difference between fuel injection and carburetion. A fuel injected engine will compensate for changes made to the intake and/or exhaust. So, if you put a different filter element on, you will not run richer or leaner than before, although you will make more or less horsepower, depending on how efficiently you are moving air (an ICE is just an air pump, after all).
V&H will send you different setting. Call or email tell them whats going on. They are pretty good about it. Try the new settings and see how it runs.
Guest
Posts: n/a
I haven't looked at what parameters the FUELPAK overwrites, but as long as it is using the O2 sensors to adjust, then no, it shouldn't be richer with the stock A/C than it is now.
After that the Fuel Pack takes over its for 4,000 RPM+ . According to Nightrider the ied's and the fuelpack work great together. I just havent gone that route yet.
I just got back from a 25 mile ride and I can smell how much more rich the exhaust and the bike is running. The difference in idle and throttle response is noticeably changed: Idle is much more smooth, Throttle response is not as snappy as it was with the High Flow but there is still a ton of torque. I will see how it goes and make up my mind with what to do later.
OK here is my thinking and I know not everyone is a fan of the FuelPak but work with me here....
I removed my high flow aircleaner, I reinstalled my stock airfilter and airbox.
I have a Fuelpak and Full Bassani Exhaust, Now I left the tune in the FP the same and the baffles are flow through..not quiet.
The stock airfilter is NOT paper its white compressed cotton or some kinda white fiber whatever it is. My thought is since V&H "Recommends" you run a high flow airfilter this one (stock) should work.
Another thing the FP is tuned too run slightly richer than stock. By leaving the stock filter on dont you think it would run a little more on the rich side???
I am gonna try this setup for a little while and see what happens....please give me your Educated opinion.
I guessing your bike did not exhibit this symptom when you first got it. Then after running with the pipes and A/C you have on it, changed the flow to the point where HDs sloppy warm up fuel programing started to rear it's ugly head.
Mine had this problem when it was brand spanking new and completely stock. Short story long, after replacing everything in the EFI system, MOCO took a SERT, adjusted the warm up mode in a new ECM, overnighted it to the dealer, they put it on and it was cured.
So if you have a real tuner such as a SERT or TTS or the likes where you can acess the tables of the ECM, you can tweek that stuff out.
If what you say is true why do you run a PCV on your bike? Wouldn't the o2 sensors adjust? Have you seen the a/f ratio of a bike with just pipes and high flow a/c and no tuner? Would you agree stock bikes are lean from factory? Why would anyone need a tuner to add fuel if the stock ecm will richen the mix as needed? Stock bikes are lean to meet EPA regs. You add a/c and pipes you need to add fuel more fuel than the ecm will allow!
Aaron, this symptom is commonly referred to as the cold start stumble. A ton of the 1200s experience it ever since 2007 when they went to EFI on them. Some exhibited it and some didn't, I think it basically depends on the airflow characteristics of each individual engine and they are not all the same.
I assumed by adding a fuelpack it would help with more fuel and stop it but I guess not....Its just stupid.
Guest
Posts: n/a
Do some actual research, don't just argue on a forum. Go to Nightrider.com, and talk to Stephen Mullens. This is what he does for a living.
Run what you want, it's not my money, and won't hurt my bike at all.
A fuel pack or PowerCommander V (PCV) will change the AFR to be something different than what the ECM is programmed for. It does this by "skewing" the return from the O2 sensors so the ECM reads this return as being "leaner" than it actually is thus tricking the ECM into adding fuel or the outputs from the ECM to the injectors thus making the injectors add even more fuel than the ECM is calling for (depends on the system and it's programming).
IN THEORY the stock ECM should read the additional flow created by new pipes and a/c and add fuel to match the increased airflow. However, the result will still be the slightly lean condition that the bike had when it came from the factory, just with a much more efficient system which should create more power (more air = more fuel = more power) but yet better fuel ecconomy (more efficency = better ecconomy at cruise conditions).
What tekdiver500ft says makes sense. After all, the ied's change the voltage coming from the O2s to the ECM to make them "read" lean. IF they work, this means the ECM is more than capable of adding enough fuel based on O2 readings. Thus unless you're wanting to richen your mixture from stock, the ECM is capable of compensating for a/c and exhaust modifications.
