Shock length for a Hugger?
Old 05-12-2011 | 11:51 AM
k&j eglide's Avatar
k&j eglide
Default Shock length for a Hugger?
Does anyone know what the shock length was for a stock Hugger? I'm going to lower the rear end on an '89 1200 and want to know what will fit. The shocks on the bike now measure 14" eye to eye. I want to use 11" but want to know if that is too low.
Old 05-12-2011 | 01:00 PM
WVHogRider's Avatar
WVHogRider
I'm running 10" shocks on my '00 XL standard. You could always put the bike on a motorcycle jack, remove the shocks, slowly lower the bike back down to the 11" mark, and then check under the fender for wheel clearances. However, you'll need to know how much the shock compression is for the actual shock you are putting on.
Old 05-12-2011 | 06:21 PM
BurpleHugger's Avatar
BurpleHugger
10 inch struts here, burly makes 10.5 shocks. As WVHogRider said...clearance and load are key
Rustyg500
09-06-2018 04:05 PM
wix
Milwaukee Eight (M8)
34
01-08-2018 11:04 AM
sbeamer
2014-2023 Touring Models
01-19-2015 08:02 PM
XL50#674
01-21-2010 11:41 AM
jbarbarian
03-18-2008 12:58 AM
