P/N 69462-06B run/brake/turn issues please help...
Hello all. I'm kevin and new to the forum. Hope im posting in the correct spot..... I have an 03 sporty 883. Recently installed 69462-06b and cut my rear fender down/bobbed. I removed the fender light assm. Within 3 days the rh taillight/turn would not come on the first turn on of the ignition. I would flip key on and off couple of times then it would come on and work fine. 5 days i had verry dim run, no turn eiher way, and they lights would go completely out. After testing bikes wiring i decided it was a bad part - (69462-06b). So i replaced..... All is well for 30 mins now the right is verry dim, and the light doesnt light up with brake either. Lh is operating ok. Any suggestions?????? Im stumpped..........
