Daytime Lights
Old 10-26-2006, 10:40 AM
balley's Avatar
balley
balley is offline
Default RE: Daytime Lights
I use high during the day. I use low when cars approching at night, I do leave them on High long enough to make sure they see me.
Old 10-26-2006, 12:02 PM
ronn39's Avatar
ronn39
ronn39 is offline
I switched to the Sylvania Silverstar bulb (9003 ST), and have been told I'm very visible during the day, even with it on low beam. I use the high beam at night and it becomes day time -- I can see the four-legged critters well in advance.
Old 10-26-2006, 12:29 PM
SportyPig's Avatar
SportyPig
SportyPig is offline
I always run brights, except if I'm sitting at a traffic light at night, and notice I'm blinding the people in the cage in front of me, then I'll usually dim until the green light.
Old 10-26-2006, 04:41 PM
Iron Legend's Avatar
Iron Legend
Iron Legend is offline
Seems like a lot are using the high beam during daylight hours. I have been using the low beam but it appears as though high might be the way to go.
Old 10-26-2006, 08:58 PM
1200babe's Avatar
1200babe
1200babe is offline
get road lamps- they add extra light at night and also make cagers much more aware you are there and it is a bike not a car with one headlight out.
Old 10-27-2006, 12:04 AM
relli's Avatar
relli
relli is offline
and a modulator!!
Old 10-27-2006, 02:51 PM
pjweber's Avatar
pjweber
pjweber is offline
Flip it to high as soon as the sun peeks over the mountains.
Old 10-27-2006, 03:01 PM
alexcue's Avatar
alexcue
alexcue is offline
ORIGINAL: 1200babe
I used to run with Highs all the time, but after i got the auxiliary lamps, mainly using the lows. Those auxiliaries combined with the regular (Silverstar) beam makes you quite visible.
Old 10-27-2006, 03:09 PM
liltrk's Avatar
liltrk
liltrk is offline
Low beam and passing lamps all the time with Silverstars.
Old 10-27-2006, 03:54 PM
jayhawk894's Avatar
jayhawk894
jayhawk894 is offline
I run low beams with passing lamps.
As an aside, my passing lamps turn off when I switch to high beams. Is that normal or just how the dealer installed them?
Quick Reply: Daytime Lights
