Lowering rear 1"
Lowering rear 1"
I have a 06 1200C, I am considering lowering only the rear 1" via lowering blocks. What am I to expect from handling differences???? Do I have to lower the front equal or leave it alone. I like the way the front end handles now with new Progressive springs and dont want to mess with the springs. I have heard I can raise the fork tubes in the triple trees and inch of equal of lowering the rear. If I just do the rear, will I need a shorter kick stand???? The reason for all this is i find I find myself almost straight legged at stops.Knees just barely bent, and thinking if I lower it, I will have a better stance and better control at a stop. I might add im not getting any younger at 61 now. I have the seat I want a Mustand vintage and dont want to change it.
Thanks for the quick replies. Is there any advantage to using lowering blocks or shorter shocks. I was looking at Burly on line and see lowering blocks (Chrome because swing arm is chrome) cost $110.00. I was surprised at the cost of just a block with 2 holes in it, may regroup and look at shorter shocks depending on answers in here. I think originals for a 06 1200C are 11.75???????????? If I could find some 11.0 for a decent price, id go with that. I need to pull a shock off the wifes 883L and compare lenght??????
Lowering
I lowered the rear of my 2008 1200C using the 11" shocks off a Nightster. I bought them off Ebay for less than the lowering kit, and I don't have to worry about the rear wheel getting up in the wiring harness and fasteners. It still handles fine.
If you need to lower the front, an option is to just let the fork tubes come up a little thru the Tree's, no need to sacrifice the ride.
My front suspension is still stock and with the rear lowered the 1" I had a couple issues with parking (uneven ground), I put a kick stand off a 1200L on and everything is back to normal.
I'm in your age bracket also and the knees, & left hip made lowering the bike necessary.
Herb
Herb
