Exhaust Gaskets...grrrrrrrr
Old 04-13-2011 | 07:37 PM
DFsporty's Avatar
DFsporty
Default Exhaust Gaskets...grrrrrrrr
OK guys, trying to re-install my exhaust and of course as many of you know from experience I'm having a hard time installing the new exhaust port gaskets. I know they are a bioatch to install but come on. I have an '06 883C and the dealer gave me part number 65324-83B, is this the correct part number? Any advice would be great.
Thanks,
Danielle
Old 04-13-2011 | 07:40 PM
2011Deluxe's Avatar
2011Deluxe
Little dish soap and they will slide right in.....
Old 04-13-2011 | 07:58 PM
Aaron48's Avatar
Aaron48
I just put on a new exhaust and got some Screamin Eagle Gaskets...I used a bent pair of needle nosed pliers and gently pushed them in with the curved side as not to damage them. No problems.
Old 04-13-2011 | 08:07 PM
Iceman24's Avatar
Iceman24
Yes, that's the correct gasket & like thegrants82 said - smear a little dish soap on them & push in evenly. Takes a few "choice" words, but they'll go in.
Old 04-14-2011 | 07:26 AM
WildThang's Avatar
WildThang
Along with soap, use something like a cap (inverted) of a spray can to push (evenly) on the gasket.
Old 04-14-2011 | 07:30 AM
XL50#674's Avatar
XL50#674
Yeah they are a PITA!!!!! for sure and they will go in and it does seem they are not the right ones for the bike. Next time I'm going to try the SE gaskets. One thing I did that helped a bit was put them in the freezer for a few hours and it shinks them a tad.
Old 04-14-2011 | 07:51 AM
xFreebirdx's Avatar
xFreebirdx
The Screamin Eagle Gaskets are the best way to go.
Old 04-14-2011 | 07:57 AM
madchemist24's Avatar
madchemist24
I used the SE this weekend, they popped right in no problem!
Old 04-14-2011 | 08:38 AM
Clayvis's Avatar
Clayvis
+1 on the SE gaskets. Using them was the only way I could get my V&H pipe to line up correctly. Those wire mesh things are a PITA. Plus, if you don't get them just right, or over torque the exhaust flange nuts, they will protrude in to the port and cause a loss of HP. (Hillside Cycle explains this well on their website.)
Old 04-14-2011 | 08:56 AM
xFreebirdx's Avatar
xFreebirdx
The SE gaskets are wire mesh.
Quick Reply: Exhaust Gaskets...grrrrrrrr
