C&C solo seat problem
Old 04-12-2011 | 12:26 PM
bmrgold's Avatar
bmrgold
Default C&C solo seat problem
My front tab on the seat keeps popping out when I am riding... I tightened the back screw as much as I could and I also wrapped the tab in some electrical tape thinking it might prevent some of the slippage but no luck still slides backwards and pops out.
Does anyone else have this problem? Has anyone solved this problem? Maybe put a different screw on the back... something I can torque more than a phillips head.
Thanks in advance!
Old 04-12-2011 | 12:50 PM
cameraboy's Avatar
cameraboy
I don't have that problem with my C&C lopro, but BARELY. It just fits. that sounds pretty dangerous. Send it back.
Old 04-12-2011 | 01:45 PM
Bagged Out's Avatar
Bagged Out
I wouldn't put any more torque on that back fender.
I agree cameraboy, send it back.
Old 04-12-2011 | 03:50 PM
Superfly3176's Avatar
Superfly3176
Did you buy, or did they send you the correct seat for how many gallons your tank is? If you have a 3.3 and they sent you a 4.5 gallon tank seat that could be the issue.
Old 04-12-2011 | 05:57 PM
bmrgold's Avatar
bmrgold
bought it used from someone on the forums... it is supposed to be for a 3.3, it barely pops out if it was 1/8" longer it would be fine.
Old 04-12-2011 | 07:56 PM
CutandWeld's Avatar
CutandWeld
Can it be modified? Adding an 1/8"?
Old 04-12-2011 | 08:26 PM
streetfighter06's Avatar
streetfighter06
I agree. Avoid the hassle. Modify the seat
Old 04-12-2011 | 10:35 PM
sajackson's Avatar
sajackson
Man I had a C&C LoPro that my butt didnt like but no problems like that.
Old 04-13-2011 | 09:26 AM
bmrgold's Avatar
bmrgold
My Butt loves this seat, I think the problem is coming when it slides side to side changing the angle of tab and its just enough for it to pop out, I wrapped it in electrical tape even more hopefully this stops it from sliding side to side to much, next step will be to put a piece of foam around it and tape that on there that should defiantly work.
Old 04-13-2011 | 09:29 AM
CutandWeld's Avatar
CutandWeld
You got a pic?
RoBeau
2014-2023 Touring Models
04-29-2019 02:00 PM
xXGingerSquashXx
01-20-2019 03:35 PM
aaamax
08-03-2017 06:42 AM
apblingAEW
06-24-2015 08:49 AM
ramirolozano
General Topics/Tech Tips
01-18-2009 09:45 AM
Quick Reply: C&C solo seat problem
