Flipped handlebars
from what i have read and been told, it is just a matter of loosening the bolts on the handlebar brace, and the screws for the housing for the lights and ignition button controls and then slide out the grips or whatever and flip bars and slide grips and controls back on tighten screws and voila!
Just remember its not a matter of turning them down. You must flip them end over end. Also advise u just barely loosen the break bango and move it to take tension off the break line. It will take some getting used to the position as its not very comfortable and puts strain on your neck, back and forearms. I wouldnt change mine back to stock, im used to it and love it.
Guest
Posts: n/a
It's very easy to do. A better comparison for comfort is: is a crotch rocket more comfortable, or a cruiser? The more important question is how do you ride? If you spend most of your time at high speed and/or carving the corners, then you will most likely be happy with the bars upside down. If you ride more sedately, then you will probably be happier with them in the stock position. If you are young, then you can probably handle upside down bars. If you are older, then your back probably can't handle it.
Another alternative would be drag bars. They are exactly halfway between stock bars and flipped bars. The downside is that they aren't free. They can be cheap, though. I got two sets from my local stealership for $25.
ZenGlide
07-14-2015 12:59 PM
TAWoody
11-08-2012 09:04 AM
883, bars, cruisers, davidson, dyna, flip, flipped, flipping, handle, handlebars, harley, motorcycle, sportster, upside, upsidedown
