Iron 883 wider rear tire???
Old 10-21-2021, 08:17 AM
slw210's Avatar
slw210
slw210 is offline
Originally Posted by CalaveraIron
Anyone knows If a 2018 road glide special tires will fit in a 2010 iron 883? They both are 16/19 and 1/4 axles.
The axles should be 25mm. The front of the 2018 road glide special will be wider than the Sportster Iron AFAIK. The rear may fit, the brake disc and pulley are opposite on the 2018 road glide special rear wheel from the Sportster's.
Check on the Wheel/Tire Forum on what's needed, might have better luck there.
Erico Huang
05-23-2018 01:52 PM
Dreamtab
12-21-2017 04:20 PM
Dreamtab
05-07-2014 06:37 PM
kantoboy
12-23-2012 09:37 AM
lucy brown
12-23-2009 09:01 PM
Quick Reply: Iron 883 wider rear tire???
