Had bad battery, swapped out, still won't turn over
So the battery that was in there was shot, or so I thought from what I could tell since it wouldn't even attempt to turn over at all. Swapped a new one in tonight and it cranks like there is nobodies busy BUT it will not turn over..........AT ALL.
It cranks, cranks and cranks but it won't do anything besides crank. Thoughts? I've checked, double checked and triple checked all the cables that I removed from the battery and surrounding wires on the rear fender in addition to other wires in the vicinity.
Thoughts?
Thoughts?
1989 Sportster 883 XLH
Anyone know where the fuse box is because I've torn this bike apart looking for it (it's not under the triangle shaped panel) as I've seen posted on the internet (the only thing under there is a solid black box that is sealed, no fuses hide anywhere).
I still don't know why the bike won't start and I'm starting to lose my patience.
Check your relays. They should also be located on the fuse panel. If you have two try swapping their positions and see what happens. A blown relay is not always obvious. They are fairly cheap to replace if you don't see any fuses blown and want to give it a shot. I had a blown relay and it drained and killed my battery.
Have a good one!
