Pastors bike is broke down.......
Received 1,773 Likes
Left for a ride with my pastor this afternoon. 3 miles down the road, his bike dies, just dies. It has nearly a full tank of fuel and the battery wouldn't hardly turn it over, yet he hadn't had any problems starting it up 'till then. Tried to push start, no go. Bike has a carb. I came home and got my car and cables, went back, and it wouldn't even start when being jumped. It turned over fine, just wouldn't fire. Any ideas.
Just curious how it can go from starting and running fine, to dead, won't start.
Well, I pulled the plugs today, figured I'd start there, and I'm getting spark to both plugs. That surprised me, I was expecting a faulty coil. So the next thing missing to create a running motor would be gas. This bike has a carb and I know nothing about them. Is there a simple check for something besides making sure the gas tank has fuel, which it does, it's nearly full. I've turned the petcock every which way, still no runny.
Any ideas/help is appreciated. Last resort is taking it to the shop, I'm trying to help pastor avoid that cost.
I think first what year is his bike?
Remove air cleaner and see if it pisses a little squirt of gas in the carb. The petcock is vacuum operate by a hose that connects behind the petcok. did that fall off. The older gascaps caused a problem with a blocked vent in them and stopped fuel to carb.
What did he work on last? when I get a new problem I think what may I have done to cause it. lol
As long as the fuel tank is full, the petcock lever can be in either the up or down position, but not sideways.
If the vacuum line to the back of the petcock is disconnected or leaking, no fuel will flow out of the tank.
