red oil in the gear case.... what
04-06-2011, 08:53 AM
2000 sportster, pulled the side cover and its red?
what is this? normal ?bad?
04-06-2011, 08:56 AM
Redline heavy gear oil. Not really good for a sporty as the tranny and primary share the oil.
Drew
04-06-2011, 09:05 AM
thats what gets me, my friend used 20-50 HD synthetic. im thinking someone added it or something.
Shall I just drain it and do a full oil change? Or do I need to flush it or do multiple oil changes to get that stuff out?
04-06-2011, 09:15 AM
Drain it completely and add Formula + or the 20/50 syn if you want..
04-06-2011, 09:18 AM
Yeah, that oil is far too thick for the shared primary/tranny. Drain it and replace with 20W50 or Mobil 1 75W-90 gear oil. That stuff is 90/140 or something liek that.
04-06-2011, 09:27 AM
It's Tiger Blood for your XL!
***I'd drain then drive 50 miles and drain again.***
Then drive another 50 miles and inspect the condition again, as in this threads pictures.
04-06-2011, 09:30 AM
I'd drain & refill at least twice with inexpensive petrol based gear oil and then refill with your oil of choice, it's not easy to get Redline SP Heavy completely removed...
04-06-2011, 11:10 AM
So it has to be redline oil someone added we don't know about. Nothing can change oil red.. right?
04-06-2011, 11:18 AM
Water will make oil look milky, nothing I'm aware of will make it look red. The fluid looks exactly like Redline's SPH which looks like Pepto Bismol red.
04-06-2011, 11:20 AM
I thought it was Dannon Rasberry yogurt.....
