Riser and Clamp Frustration
Ok I think I found what I need...sort of.
It looks as though the wires that connect to the little lights (blinker oil etc) is a harness that can ve replaced. I believe this is what I need to do bc my lights connect to the speedo via four little pinch clips where as every other non custom seems to mount with two smalls screws. It looks like something that is done without making me cut and solder anything.
So does anyone have the part number or link to where I can purchase this harness and light set up?
Refer to post #3.
You don't need a new harness. You need the little components that make your existing lights mount with the screw system. It would help if you could look at an assembly drawing in the Sportster Parts Manual. Try your local dealer. It sounds like your speedo is going to be about vertical.
#2325 Screw 2x1.99=$4.00
#2361 Screw 2x.99=$2.00
#68513-95 Bezel warning lamp housing 1x2.99=$3.00
#68516-95 Housing, warning lamps 1x11.99=$12.00
#68551-95 Warning Jewel 1x18.99=$19.00
Check out Flatlanders pics.
Let us know how you do.
Refer to post #3.
