wiring Z bars
wiring Z bars
someone please tell me the trick i got drag z bars and i am lost they came w/string laced through but when i did the move they were getting stuck on that z angle....
im calling places in the morning to get prices to see how much to get them wired and save myself but if its easy enough lmk...
It takes a while! The Trick is to tape off the other side and if lose the string use an air compressor to blow it back through. You can either do one wire at a time or, Tape them all together in a really tight bundle and lube the **** out of it and pull it though. It usually helps if you have someone pulling and someone trying to feed the wires. I got the Short Z bars on mine and I couldn't stand the look with external wires all over the place so I did internal. I know now why most don't run internal because it's a lot of work and difficult with the sharp edges of the bars. It took me a good 3 hours to get mine wired but I saved hundreds from a dealer and personal satisfaction. When it's done you'll be happy. Take your time and be patient it will work.
I found using the string that is in there to pull 2 strings through .
The tie one to the very Tip of the cables (tape works) and other about 1/2 in -1 in down.
keeping steady pressure on the one that 1/2 and working the Tip one will help clear the Z spots much easier.It helps it turn the corners really nice. I use to run them back in the day for a bunch of friends.
When I did mine, it was an absolute PITA. First lesson learned was to cut the wires instead of taking apart the molex connector. I wound up bending/breaking the pins on a few wires. I also realized that in order to get past the 2nd bend you have to only do a few wires at a time. I created a loop with my pullstring so it would always be inside the bars. Patients is the key. I almost got fed up and had a shop do it. When they said $150 to wire them, I became even more determined. Good luck and make sure to check the insulation on the wires whenn you are done. The may be nicked a bit. Crappy cell phone pic attached.
Hey Soft 02 for some reason I guess my pics are to large to put on here but if you want to see my Chopper just shoot me an email bikerguy_76@yahoo.com and I'll send ya a couple pics. thanks
