What is difference between 1991 and 04 exhaust.
The position of the rear brake master cylinder will prevent 04 and newer exhaust from fitting your machine. Blueing is caused by the fuel mixture, not the pipe. If the carburetor is set lean (factory stock), the pipe will get to hot and turn blue. Use Blue Job chrome polish to remove any discoloring on chrome.
I can't remember what the model is but I had Radii pipes on one of my 03's and they sucked.
You can move the master cylinder wherever you want but I think you'll also have to modify forward controls if you have them. If you can fab parts like that I think it would be much simpler to just make your own exhaust. If you'll be paying a shop to do the mods then I still think it would be cheaper & faster to just take your bike to a small exhaust shop & have them make what you want.
