Rocker Box Gasket Failure Rate
Old 03-16-2011 | 09:17 PM
ntg433's Avatar
ntg433
Default Please explain further...
my mechanic at the dealer said , "do you warm it up before hitting the trhottle" i always make shure the rocker boxes fill warm enough before taking off[/QUOTE]
I don't understand this. How does a warm up ensure that the gaskets for the rocker boxes don't fail? I can understand that a warm engine expands and that might seal a little better before you put some throttle and circulate the oil a lot more, but as a preventive, I don't see it. Wouldn't this be happening in the automotive world also? Don't mind me I'm a harley noob.
Old 03-17-2011 | 08:14 AM
WVHogRider's Avatar
WVHogRider
It does happen in the auto world too, but most people rarely ever even lift the hoods on their cars nowadays to even look at their engine. Out of sight, out of mind kind of thing. And I highly doubt the techs doing the $20 oil changes at the quick lube places are going to say anything.
Old 06-29-2011 | 07:26 AM
UpNorthIron's Avatar
UpNorthIron
6th Gear
my 2010 Iron is going in for its 2nd rocker gasket replacement (leaking worse than it was the first time only 1200km later). Had them replaced due to leakage at 3900km.
I'm going to try warming the bike up more before I ride, but I don't like running it too long or it pisses the neighbors off.
Old 06-29-2011 | 07:31 AM
xFreebirdx's Avatar
xFreebirdx
Use Cometic Gaskets or James Gaskets. Problem solved.
Old 06-29-2011 | 07:39 AM
Voony's Avatar
Voony
Originally Posted by Bobber Jake
I just did both of mine myself this weekend. They are pretty easy as long as you have a service manual and a torque wrench. It was the first time I ever tore into my engine and I was suprised at how easy it is. And the gasket kit (cometic) was only $35 at dennis kirk.
Ditto. I just swapped my rear rocker gaskets this weekend. If you do it yourself, I recommend buying the flat wrench and the Cometic gaskets, all at DennisKirk.
Took me 3 hours and a half just for one cylinder but saved me $200 in labor :-)
Old 06-29-2011 | 08:55 AM
hjc950's Avatar
hjc950
Default Cometic or James Gaskets
I have replaced mine twice in 22K on my 07, takes about 3 to 4hrs (I'm sure a Harley can better that time by at least 25 to 30%).
The Cometic gaskets are identical to HD's gasket in "Material,durometer, and Shape", wouldn't be a bit surprised if they get their gaskets from Cometic.
I'd be curious to know what the James Gaskets look like.
Old 07-01-2011 | 02:34 PM
RBar's Avatar
RBar
Angry Just fixed my front...
At 14,000 miles, had a leak from the lower valve cover gasket, the one above the head, but below the top one.
I pulled off the top valve cover, perfect gasket there, original.
BUT, the front bolt (of three...the most forward bolt...) was loose, out of it's hole, bouncing around near the front rocker arm!
I screwed it back in and decided to run it with the original gaskets to see if that was the problem. Everything OK now, or at least, for now.
There's some touted Harley "hidden technology" for you...
I would NOT replace a good gasket, regardless.
Originally Posted by Kenny94945
For EFI Sportsters, is it not if but when will these gaskets leak?
In other words, do some never leak?
Should they be periodically changed...like every 10K service?
Are their 4 small circular gaskets and the large square gasket per cover...anything else? Also what is the typical cost of parts for this leak repair?
lkr0
03-24-2014 08:24 AM
Roni
08-17-2013 02:01 AM
flat4fan
08-23-2012 09:45 PM
texasridr
EVO
17
06-06-2009 11:20 PM
TwiggyAZ
Exhaust System Topics
04-04-2008 12:19 PM
Quick Reply: Rocker Box Gasket Failure Rate
