Rush Slip-on Discoloration
After riding into work this morning I noticed some slight discoloration on my Rush slip-ons where the muffler meets the header pipe. Almost looks like the metal is overheating. Was curious if anyone else has experienced this.
Over the winter I installed a SE intake, ViEDs (set to 14.0:1 which is the middle setting iirc). Was thinking that I might still be running a bit lean, when I first installed the slip-ons last summer I did notice a lot of decel popping but since installing the ViED it seems to have dissipated.
Just trying to figure out if I'm being overly paranoid since she's been sitting for most of the winter or am it running too hot.
Will take a couple of pics once I get home, currently at work and unable to do so.
Had the same issue - check the thread here: https://www.hdforums.com/forum/sport...colouring.html
I only installed the slip ons as there is no strict need to do stage 1 with only slip ons. After posting the pics Rush sent me new ones. They said they had re-worked their powder coating which may have been the reason for the discolouring.
Either way I will be tuning the engine when I install them as I live in Dubai and the moisture could be an issue.
Good luck
Good luck
Thanks for that link Dim, after looking at those pics you posted the discoloration I'm seeing looks almost exactly like that just not as far along.
By the time I get home it'll be dark out so I'll have to wait till Monday to take some decent pics but I'm going to be sure to send them in so Rush can have a look at it.
Yup, I make sure to clean the slip-ons thoroughly, well the whole bike for that matter, anytime I do any sort of work on it. I could understand if that's what the problem was but it's not. The area affected is just where the slip-on meets the header pipe and nowhere else.
These are poweder coated? Am I supposed to read between the lines here?
OP didn't "say" they were powdercoated.
Most nobody will warranty chrome ones for discoloring, since poor tune ain't the pipe factories fault.
They also said that if you were just using slip-ons then there is no need to tune so they still warrantied them for me - and shipped them to Dubai FOC. Nice.
Ryan
Also, nice to see a local on the foum. Our facility is in Merrillville.
