MY '09 IRON 883 Sucking Gas a lot!
What do you mean by "Both the time the gas almost ran,"? Ran where? Ran what? And again, exactly how much gas did you put in? Not how full you filled it, but the exact amount of fuel you put in.
In order to figure out mileage, you need to fill the bike, clear the trip odometer, ride it for a while, then fill it up again, noting the exact amount of fuel it takes to top it off and the exact mileage on the trip odometer. With those two numbers you can use simple division to get your accurate mileage. Then clear the trip odometer again (do this at every fill up).
Again, if you go through 3 gallons of gas in 50 miles, you will notice either a leak or crapping running.
Also take this time to check EVERYTHING on the bike. Slowly go through and look for anything (with exception to wear and tear) that you can have the dealer check out and repair under warranty. One common thing is to look around your rocker box covers for any signs of leaking oil.
Don't expect them to do that for you as they will usually only fix what you bring it in for and ignore anything else.
Sounds awesome man, let us know what they find out!
I do think that you are correct and hopefully that will be one of the things they check out when they are working on his fuel problem. But, never hurts to REMIND the wrench!!
I am also curious as too how much gas your actually putting in the tank. For example when i stop and put gas in my 09 iron, i usually am able to put about 2 to 2.3 gallons in it max. Then i go ahead and ride another hundred miles or so, pull back into the gas station and fill up again (around 2 gallons) Like others have said, no way your getting the full 3.3 gallons in there. Also you said you filled it up to the top, but how much was that?? I would have a shop look at it for sure, let us know what you find out.
