Removing Military Stickers From Front Fork
Anyone have an idea of how to remove my military sticker from my front forks? I have tried a hair dryer, and every solvent I can find that won't destroy the aluminum. Nothing seems to be able to penetrate the mylar face and dissolve the adhesive.
I have scrapped off a piece the size of a dime with my thumb nail, but that is all. Any suggestions will be greatly appreciated.
Yep, going to need heat and/or solvent plus the scrapper. Those things are a BITCH to take off. That's why I got a military decal bracket for my bikes. In this picture it's the "glowing rectangle" by the front cylindar. This is the one designed to be bolted to the front caliper of the big twins...just zip tied really tight to frame.
Use an old credit card to scrape at it if you must scrape. Razors will cut the clear coat.
Ditto on the WD-40, but if that doesn't work try a product called "Goof-Off". A citrus-based solvent that works pretty good and doesn't have a solvent odor is "Goo-Gone". If you get the solvent around the edges, sometimes you can peel it away a little at a time with little effort. If you're not careful with heat, it may dis-color the clear coat.
