spark plugs
Old 02-27-2011, 10:12 AM
cHarley's Avatar
cHarley
cHarley is offline
In looking at the E3 xref chart, I don't see a suitable cross-reference listed for any of the below plugs, all of which are xrefs for the Harley plug.
Champion RA8HC
NGK DCPR7E
Autolite 4164
Bosch YR6LDE
Denso Iridium IXU22
Old 02-27-2011, 01:16 PM
Krull883's Avatar
Krull883
Krull883 is offline
Champion RA8HC
NGK DCPR7E
Autolite 4164
Bosch YR6LDE
Denso Iridium IXU22
Here is a link to E3 that says the E3.36 works in a 07 883 sportster. Go to page 24
I just got back and the store only had one. I will get them another day..
http://www.e3sparkplugs.com/pdf/powersport_catalog.pdf
Old 02-27-2011, 01:23 PM
Krull883's Avatar
Krull883
Krull883 is offline
Originally Posted by Aaron48
I have an E3 in my snow blower. I have had to only put gas in it once this whole winter. The blower runs smoother and stronger I like em.
I have noticed that the smaller the engine the more you notice how good they are. I only use Husqvarna chainsaws and they start alot easier with E3s in them. My dad uses them in a '59 Bel air and he tells me the car runs smoother and starts alot easier.
Old 02-27-2011, 03:29 PM
Osco's Avatar
Osco
Osco is offline
Account Deactivated
Better spark plugs may last longer,,,
If yer set up and running the right fuel a Fancy spark plug
only makes ya think yer faster..
And empty's yer wallet faster,,
Plugs In a Sporty should be changed at 10k Intervals.
Cleaned and regapped every 5k,,
Old 02-27-2011, 03:39 PM
Krull883's Avatar
Krull883
Krull883 is offline
My bike is not for revving up or impressing anyone. I got it mostly to comute and have fun with. I dont plan to rev it to show off and it is 100% box stock. In every instance I have seen E3s used they do improve fuel use.
Wont hurt at all to put in the 883 custom.
Old 02-27-2011, 05:16 PM
leistritz's Avatar
leistritz
leistritz is offline
I have the e 3's on my 08' Nightster. I havn't had a problem with them. They've been on for a year now and I like them. It's probably all in my head but the bike seems to run smoother and is more responsive. I was sceptical at first but after running them on my 07' Streetbob, I put a set in my nightster. They are the same part # for the 07' SB as the 08' Nightster. I thought, for a little more, I'll try them. Whats a couple of more dollars for a small performance inhancement. We all spend far more money on other things that really doesn't net us any performance enhancment. Now I run the E3's on all my other stuff..... mower, leaf blower, echo trimmers... all my stuff. I've run NGK's, SE, ect and if a couple of dollars makes me feel like its worth it, then its worth it. All in all, I don't think certain brand of plugs are going to make a huge difference but various plugs work for various things... like I ran a little hotter plug back in the day on my 89 FXR Lowrider because my bike always ran alittle rich and a hotter plugs help some with that ect. Try them, you don't have anything to loose. Thats my 2 cents
Old 02-28-2011, 10:38 AM
heybaylor's Avatar
heybaylor
heybaylor is offline
yeppers, sparkplugs are a billion $ business..
Why? cause most people can change them , most can afford the "very best "...(smile)
they are the most overchanged object in america..
what ever is wrong " change the plugs"
carb lean? =change the plugs ....carb rich? change the plugs
choke /enrichment circuit not set right ?=change the plugs
lol, as soon as I get my current "splitfires" paid for I am going to see what the latest "magic plug is out there...
Old 02-28-2011, 10:49 AM
XL50#674's Avatar
XL50#674
XL50#674 is offline
I always run OEM plugs in everything and never have an issue. Just run HD plugs.
Old 02-28-2011, 11:32 AM
WVHogRider's Avatar
WVHogRider
WVHogRider is offline
Or use the Champions listed above because they make the HD plugs.
Old 03-04-2011, 06:02 PM
Krull883's Avatar
Krull883
Krull883 is offline
I just got the E3s in my bike. Starts and runs just fine.
The E3.36 plug is for sure the right one for an 07 883..
sk1sk1
07-14-2017 11:18 AM
grunt25inf
09-18-2007 02:06 PM
acedantinne
09-17-2007 12:16 AM
grippper293
07-01-2007 11:13 AM
Shift_4lo
03-11-2006 03:37 PM
Quick Reply: spark plugs
