Sportster Speedo in KPH
Maybe contact Autometer and see if this will work for you. It can be calibrated for most factory speed sensors. Or maybe they will have something else that will work, I would give them a call.
http://www.autometer.com/cat_gaugede...id=3500&sid=59
I've seen guys here that had the numbers printed on small pieces if paper positioned in the right spot then lay some clear packing tape over it. It was good enough to get through JCI and that's all you need. If it comes off then it's cheap and eay to fix. Plus, after it passes the inspection ya don't need to worry about it for 2 years when it's time to run it through again.
Dakota Digital Gauge:Fits stock mounting cup without modifications (does not fit Dakota Digital mounting hardware)
Fully adjustable 0- 255 MPH or KM/h Speedometer.
Arching Tachometer with adjustable shift point, can also be displayed as a digital numeric readout.
Gear Shift Position Indicator (3 to 7 speed transmissions).
Odometer with Dual Trip Odometers.
Voltmeter with low voltage alert
Clock
Cylinder Head Temperature (on models with factory head temp sensors).
Resettable Miles to Service with warning (user settable countdown) and hourmeter.
Various indicators can also be displayed such as Check Engine, Low Fuel (if equipped with factory fuel level switch) and Security Indicators.
Several performance calculations include: 0- 60 time, high Speed & high RPM recall, 1/4 mile time and speed.
Chrome or Black front bezel .
Machined aluminum housing.
Clock
Clock
Clock
I know this but they still don't offer anything for a 97
Kuryakyn makes replacement gauges at m&mcycles.com or if you want to pay a Higher price from cruisercustomizing.com and they will not send a tracking number. Plus get this. Prices are subject to change after you buy items. But they offer $10.00 off your next order over $100.00 Just stay away even if you send the items back for a full refund. They drag their feet on refund and replacement. motorcyclesuper.com will price match,not the sharpest knife to deal with. do the research and find the model and color you like. no one can do the thinking for you!
