Small, cheap & easy do it yourself CRANK CASE BREATHER
to go with my small, cheap & easy do it yourself air cleaner.
I started by drilling a hole through a 1" long 1/2-13 bolt and tapping the end 1/8" npt.
My original idea was to tap it 1/4" npt but the bolt diameter isn't big enough. But I had already ordered these 1/4" npt breather fittings
so I had to pick up these 1/4" to 1/8" reducing bushings.
Here it is assembled.
I'm going to order 1/8" npt breather fittings because I want to see what it looks like without the reducer bushing.
The whole deal was just a few bucks.
Thanks for looking.
Thanks for looking.
I started with 5/32 then 7/32 then finally 11/32.
The small pilot is necessary because you're essentially drilling through over 1" think material. When you step to the larger bit the shavings will be able to fall through the hole and out of the way.
You can go straight from the pilot bit to 11/32 but I like to step it to save my bits.
