Anybody done any frame mods? I have questions
so, I think I do want to stick with my stock frame, seems to be the most cost effective solution. Here is exactly what I want to do
The whole reason for this is I'm 6'4'', I need more room, and eventually a bigger motor. I'd like to do an arched backbone, but I don't feel comfortable in messing with the neck of the bike, I'm a good welder, but I don't want to modify the neck if I can help it. I'm just wondering if anyone has done this before on here, if they could give me some tips on where I should cut it.
I had my frame done sort of like what you want. I didn't do it myself, but had a shop do it for me. They cut it right in front of the jugs and added a 4" extention in there. Then they cut in under the seat and put in an angled piece there. Since I didn't want to extend it much, there wasn't much under the seat except a small angled piece, just so the backbone met the downtubes. It came out good, and yes, as mreed said, the motor mounts needed to be extended. The bottom of my frame was not touched though.
I am pretty happy with the way mine turned out, but kind of wish I had gone up 6" instead of 4", and maybe did a 2" backbone stretch to it.
I don't trust my welding enough to mess with the neck. I need more leg room, that's why I want to extend the bottom part of the frame. I've been looking all over the internet on how to do it, and all I can find is how to build frames from scratch with an expensive jig. I think if I cut it right I can get the lower mounts to stay put, and get a longer belt. If not, it's not a big deal to move them.
question: why not make it easy on yourself and just stretch the swingarm 4"? that would give you the length you want. Sometimes I just don't see the vision of a cool build (wich is what could be happening now) but I think that frame would look funky the way you are planing on cutting it up...way too much gap between motor and down tubes IMO. Good luck with whatever ya do
Lol...when I see something that begins with "question:" it reminds me of Dwight from The Office.
