08 1200c buzzing whirling sound when switch turned to run.
Got a 08 1200c that if not run in a while, i go to start it turn the key on flip the switch to run and it makes a buzzing type noise. Then when you hit the start button bike starts right up but with a whirling sound that follows that goes highier pitched but quites after like 3-4 secs. Like I say only does it if I dont ride for awhile, but if ran every day it dont do it. Any suggestions?
Should make the sound just about every time the bike is put to run, it is normal. As stated, fuel pump. You can even stick your ear to the gas tank and hear it loudly.
How to start the bike.
1. Turn the key to run.
2. Hit the ignition switch to run. You will hear the fuel pump spin for about three seconds.
3. Wait until the little yellow key light goes off.
4. Hit the start button.
Ride safe!
Ride safe!
Mine has done that a couple times in the past 3 1/2 years I've owned it, but never had a problem at all with it.
Ok glad to hear that others know what Im talking about. The bike runs good and everything, just wanted to know if anyone else had the same issue and if it really was a big deal or not. When I first heard it the only thought I had was that the pump was dry or something. Thanks for the posts.
my 09 1200L with 418 miles on it does it after sitting for a few days. I was a bit surprised the first time i heard it, but its not an unfamiliar sound to me so it was of no concern as it went away after a few short seconds. If its a persisting noise then i would probably check it out.
my recommendation: don't go more than a day without riding it.
eviltwin415
08-27-2010 07:51 AM
