Extended belt for 06 xl sportster
Who's stretched swing arm is it??? Because most every manufacturer already has those things figured out before they sell them and know which belts fit properly. In which case you should ask them.
If it is going to be a home-made swing arm, then I would start with the belt's available, such as on Softails, and go from there. Design the lenght of the swingarm to match the belt you can use.
