Last edit by: IB Advertising
DIY - Air Cleaner
• Step by Step Instructions
• Parts Needs
• Visual Guide
Read full discussion below
• Parts Needs
• Visual Guide
Small, cheap & easy do it yourself air cleaner (lots of pics)
#551
Received 4,199 Likes
On EFI models, some guys run without the support bracket. Unlike the carb models, the EFI throttle body is all bolted solid.
However, it is not a bad idea to have the extra support of the bracket to take some of the stress off the intake manifold.
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
#552
Better performace to route to the atmosphere. Engines like cold dry air. When you route the hot oily air from the crankcase pressure back into the cumbustion chamber you will have reduced performance and reduced longevity of the engine due to carbon build up.
#554
Anyone managed to source the filter (or one like it) in the UK?
I've tried all the usually places -- Wilco, Halfords, independent motor factors and (of course) Ebay, and can't find anything like it anywhere. Lots of conical and pancake-type filters but nothing that comes with a backing plate, a lid and a filter within.
(BTW, yes, I've read through all 56 pages of the post.)
Been said many times but... thanks mreed for a great mod.
UPDATE: Okay found em (and the louvered ones). After much searching I discovered these are sold in the UK for aircooled VWs -- buses and bugs. VW performance and aftermarket parts suppliers is where to look in the UK.
#555
Alright gents I am a bit of a noob, but I was wondering if I needed to purchase anything other than the support bracket and a 4" cheapy filter. I have bought the filter and housing but I wanted to make sure prior to tearing into it.
My bike is a 08 nightster.
After reading through the thread some more I answered my own question..... I need to buy the mount with the crankcase venting hardware included!
#556
Also be aware that 'tearing into it' is a simple matter of undoing two, then three, then two more bolts to remove the stock filter system: two holding the outer cover, three 1/4-20 holding the filter to the back plate and throttle body mouth and two 1/2-13 holding the back plate to the cylinder heads.
If anything goes wrong, returning to stock is a simple matter of reinstating the ham can and tightening these bolts. You can even reuse the two fibre gaskets if you're careful.
Yes, you will need to construct (or buy) a breather system. Many opt for breather bolts or else tap two 1/2-13 bolts to accept npt-threaded breathers (used in the pneumatics industry).
Make sure you read through a sizeable proportion of the posts here before starting so that you're familiar with what's required/to do.
Good luck
Good luck
#557
#558
Hi Orangeade
Would you mind sharing the web address where you have found them or the part number. I still cant find them in the UK.
Thanks
Jak...
Post 554.
Thanks
Jak...
Post 554.
