Last edit by: IB Advertising
DIY - Air Cleaner
• Step by Step Instructions
• Parts Needs
• Visual Guide
Read full discussion below
• Parts Needs
• Visual Guide
Small, cheap & easy do it yourself air cleaner (lots of pics)
#232
Yeah. It's cottong like a K&N. Just make sure it dries all of the way.
On my Buell I made a little catch can with a ball valve on the end of it. Filtered & vented great & when I changed the oil I'd open that ball valve to let the residual drain.
Gravity is what's causing it to come through that filter. If I use that filter/hose deal I mount the filter above the crank case vent holes like this.
#233
I use fuel injection hose so it won't collapse. The bend isn't tight. It runs straight down then around the bottom of the carb up to where it is. I later moved it because my wife didn't like seeing it (that was on her bike).
But here's another idea since this thread keeps popping up.
The carb mount kit comes with head breather bolts and spacers with a barbed nipple to hook the hose to. If you pull that nipple out the hole left behind is the correct size to thread 1/8" npt.
And that's it. Thread in the 1/8" npt breathers and you're done.
This works very well because the bolts that are drilled all of the way through are weakened and some people are a bit confused about how little torque is required to hold the carb bracket on...or, don't notice that the holes in the cheapy carb brackets don't exactly line up with the heads ending up in a broken bolt.
And with the vent facing up and the bolt having its own hole that doesn't line up with the vent the oil shouldn't escape.
Not to mention that it's super easy and everyone can do this one.
#238
If you have a Fastenal in your town they can order them. McMaster Carr also has them on their site BUT I've been ordering them from MSC because they're polished.
http://www1.mscdirect.com/CGI/NNSRIT...2+npt+breather
