48 pegs
48 pegs
So I know that there is a problem with putting aftermarket pegs on the 48, but what exactly is the problem? Is it the angle of the female connector or is each size a different size? Just wondering if pegs that are rotatable would be the cure or am I going to have to find another fix. I know member 4t8 makes a good product but I like the motocross style pegs like RSD and I think I could fabricate something rotatable out of it.
I put some metal flake Hippy Killer pegs on my 48. You have to grind down the part of the peg mount(chrome part) that sticks out farther than the other side. You can buy an earlier model peg mount that will work with aftermarket pegs, but they are expensive. I just ground mine down and the pegs go on perfect.
my bike is at a friends house in his garage and I wont be over there until next weekend.Its the very outside part that your peg goes into. Basicly it is the chrome part were the pivot bolt/mounting pin is(well just past that). the very outside spot is off set or not even with each other. Some reason Harley made it so you have to buy there pegs only. My new pegs would'nt bolt up due to the 1 spot that stuck out too far. Its the very outside part of the mount that is rounded off on the end. Had to grind about a 1/2 inch to match the shorter spot.
Received 4,193 Likes
We make quite a few pegs that will fit your 48 just fine. 2 minute install.
Check em out Here.
Got a guy entering his 48 in a show this March in the UK that has the BulletProof pegs.
Check em out Here.
Check em out Here.
Check em out Here.
Do you make custom pegs by request?
Yes, we also make one-off pegs. Can PM me or use the Contact Us on the site.
Only alternative to grinding and making custom pegs is buying the nightsters peg kit which will fit the 48 and that will change your peg setup so you can use just about any sporty peg.
