tunning help!!
tunning help!!
Hey guys, I just got a set of V&H twin slash for my HD Iron 883, I'll be getting next week the SE stage 1 air cleaner. The question here is, what should I do next??? some people say that I have to do an adjustment on the fuel/air (by downloading a software on the dealer), some say I dont need to do anything else.
What to you recommend me???
Do not, do not, do not do a dealer download. It is also EPA compliant and in reality, all it does is add $180 to the dealer's till. Yes, your bike comes from the factory but, when you open the air filtration and exhaust system the bike's fuel mgmt system will adjust back to the14.7:1 AFR that it started with.
Bwana
Bwana
My advise. Just drop a C note for a set of X14ied's from Nightrider. 5 minute installation. Changes the A/F mixture to 14 to 1. My bike runs cooler and is as smooth as butter. I can sometimes smell the richer exhaust fumes at hot idle, so I know it's working.
I have a BUB 2into1 pipe and Velociraptor A/C but no other engine mods yet. 2010 883L
Ok coming from an Iron owner.. I just went threw this myself. Every comment led to a question, every suggestion to a bias. It was hard just figuring out the difference between them all, I ended up with a PCV. it works good but its hard as hell to get help on how to tweak it. Fuel moto is good with giving you maps but if you want to adjust your on your own. All you really have to do is ask yourself this:
How much do I want to research?
How much do I want it to do and will I ever F with it anyway?
And how much do I want to SPEND!
If you plan on upgrading more on your bike you may want to lean towards a higher end programmer like A PCV, THUNDERMAX, SERT, etc. If your good with just pipes and a A/C then I would check out that X14IED, its what I wanted to get but was afraid its limitations would come back to bite me.
hope this helps and I hope more chime in. Good Luck
Irontater
07-28-2011 11:10 AM
