2007 XL883L tipped wont start
01-16-2011, 10:39 AM
I have seen starters take hits from shock alone, which can cause the spur gear to break field and not engage. Shock can damage a starter too, just not common.
01-16-2011, 11:57 AM
Quote:
Originally Posted by
Galderdrone
Both relays and all fuses are good. I do get turn signals when ignition is on.
How did you determine that the relays are good? Try switching the relays and see if it starts. One of the relays is for the starter. Just switch that with the other one.
01-16-2011, 12:54 PM
Ya I just switched the relays and they work. I will try to remove the main fuse to see if that works.
01-16-2011, 01:01 PM
just a shot
1-bike not in gear?
2-kill switch is (on)?
3-key to the start mode not acc. mode?
4-hit starter should start
5-activity you hear is fuel pump
01-16-2011, 06:58 PM
Thanks RatRod! It slipped into gear! Goin now!
01-16-2011, 07:24 PM
Your bike doesn't have a Neutral indicator? lol...
01-16-2011, 09:47 PM
It's the simple things we usually overlook.
01-16-2011, 10:32 PM
Gpsjr10
Dead on... you beat me to it!
01-17-2011, 12:27 AM
I tipped the other day...jeez. It started straight away though.
nutsandbolts5212
03-20-2023 08:28 AM
ghost183
Electrical/Lighting/Alarm
27
06-01-2018 10:15 AM
floryder
General Topics/Tech Tips
03-29-2017 12:00 PM
WLDBIL
03-11-2012 04:03 PM
gaustang4me
10-26-2008 08:53 PM
2007 ,
883 ,
alarm ,
harley ,
reset ,
sensor ,
signals ,
sporster ,
sportster ,
start ,
tip ,
tipped ,
turn ,
wont ,
xl883l
