anyone remove harness plugs w\tank lift?
Allready did tank lift...was fun fitting harness with the (I believe it was) 4 big plugs under tank(did it last spring). Was wondering if anyone cut out the plugs and soldered the wires back together to clean it up. Am debating doing it this spring...
Will be removing the tank anyhow to install D&D Bobcats and XIED's.
Was also wondering if you remove the plugs can you still run wires on top of frame and set tank down without a lift?
Any help would be appreciated...
good point...
Thinking it would just be easier to get at headers and not hit the tank with ratchet while removing - also it was an excuse to get at the harness and clean it up a bit.
Right now I have it taped as 1 big bundle and zip tied to top of frame, was gonna try laying it out flatter and possibly work it around the frame hoping I could set the tank level without the lift.
This is why I asked about removing the plugs and soldering the wires together - looks simple enough the wires are all color matched. Was hoping someone else had done it and could offer any advise.
Wouldn't hurt anything, I would pull the big bus fuse first just to be safe & make sure to solder everything & use heat shrink to avoid shorting.
I also would like to know if it's possible to be able to clean up the wiring this way without lifting the tank as I prefer the look with the tank low.
Did it on many show cars, just not a motorcycle. You have to be careful not to run the wires too far for loss, but with a bike that should not enter into it at all.
