Hands Tingling
All good responses,, and I'll add, adjust the levers up a little, and have her cover the brake and clutch levers with one or two fingers.. (but only if she feels comfortable doing it)
It helps a lot, because with levers up a little and one or two fingers on the levers it forces you to relax your hands and forearms. It is an old motocross racing trick.
Guest
Posts: n/a
Good answers so far. I'd also add that the tingling can come from problems in the shoulder, tension in the upper body, mis-aligned vertebrae and other nerve issues in the neck, and carpal tunnel. Fit the bike to her first, then get her to relax hands/wrists, then relax shoulders. If the problem persists, get her checked for carpal tunnel and nerve issues in the neck and shoulders.
I had the tingling issue with my FXD, and the vibration-reducing gloves made it worse. Thin gloves give a better feel, and cause you to relax your grip more, and might be another contributing factor.
Fitment of the bars may be a contributor, but make sure that the when her hands naturally lie on the grips, regardless of the height the bars end up after adjustment, you want her wrists to be straight when she rests her fingers on the top of the levers. So you might have to loosen and adjust the lever height to compensate for this level appearance. As another mentioned, padded gloves will help and she should be wearing them anyway for abrasion protection in the event of a crash. If it's tingling in just the throttle hand, that will get better as she gains strength in that hand. If it's tingling in both hands, then it's due to vibration and there are other things to be considered. Make sure that the front tire is not over inflated and that everything in the steering column is properly torqued.
