Carb/Jetting Help
Carb/Jetting Help
Ok I need some help. It seems no matter what i do this thing is running like ***. Now I can't even get to start unless i take the air clear off and stick my hand over the carb, then fuel comes flying out and it starts.
When i had the carb apart the slow jet was stripped and stuck (i don't even know the number on it.) the other jet was a 160. I replaced it with a larger one but for the life of me i cannot remember what size i put in there.
So i guess my question is....what size jets do i really need? I have a spare 42 jet sitting here so thats an option as long as it is not too big...
A little info on the bike
It's an 883, with pipes (no clue what they are but they are a straight pipe design) and i believe it is a different air cleaner but i am not sure, it does have a k&n air filter on it though
I have messed with the air fuel screw, hell it may be messed up too, i have a spare carb coming in i just want to put the proper jets in to start with
someone also said the petcock could be shot and just pouring fuel. is this possible?
oh also i am not sure if it matters but i use 93 octane gas (i have no choice here)
ok well i got out the slow jet...an easy out and a little "love" and it came right out
The main jet that i put in there was a 175 I can order a 170 though not an issue
here are some pics
you can see here the freaking needle looks a little bent, will that cause an issue (i assume it would)
does anyone know what this little guy is? it was in my little baggy of extra parts... didn't come off this carb but it is from a carb
i assume this is how the bowl is supposed to react lol
here are some pics
Float Adjustment
The adj is like .437 with the carbed tipped at a 20 degree angle
