Nothin' when I push "start" button......
Came home from dinner tonight and lights out in the garage. Narrowed it down to an outlet, no breakers tripped, just a dead outlet. This just happens to be the outlet my battery keeper is plugged into for the sporty. Don't know what made me wonder about it but I decided to make sure the sporty was ok. Turned on the ignition & everything comes on like it should as usual, engage "on" button, wait for fuel pump light to play out, hit the start button and nada. No noise of any kind - no fire whatsoever. Plugged into a good outlet, took about a half hour but charger finally showed a full charge, tried again - same thing, nothin'. I got lights, horn, indicators, everything just no start. Could my ignition have fried when the outlet blew? I have no testing devices and no electrical savy so it's probably going to the shop. But before I take it in anybody have any ideas? In the meantime I'll leave it on the keeper all night. Would appreciate any constructive input. Thanks.
check your fuses. Are you sure it is just that outlet? Makes no sense that just that outlet goes bad. There is nothing to them except a copper plate and it takes a beating. I would look into the charger to make sure it is not shorting out. Something made that outlet go bad. I would also check to make sure no breakers were blown as this one could be on its own breaker or on another. and back to the bike check fuses and like you said the harness to make sure nothing is burnt. then check the battery and such.
Do you have security? Do the blinkers flash when you try to start? If so you may have a dead fob battery. Cant see how a power outage could cause a problem. My tender comes on as soon as you plug it in. There isn't a switch. Plus the I would bet there is some sort of fuse protect in the tender
