Aluminum Dull Engine case
I know its a lil off topic, but I intend to spray/ powdercoat my primary casing, trans casing, sprocket cover, derby cover, etc to black.
I was wondering if I spray it with high temp spray, will it last? Its a cheaper alternative than powdercoating and I've seen this HD brand black spray that really gives the effect that I want. I'm quite sure the primary case and sproc cover will turn out fine but what about the left side? Its gets quite hot there.
And after sanding it, is it necessary to prime it first before spraying it?
