Hub spoke hole patterns
I can almost guarantee it has to do with the different requirements for support of the spokes. Spokes work great in tension, and only in tension. The different size, as well as a narrower design on the 21'', probably require different patterns on the hub to successfully reduce the stresses due to their differences in size. My suspicion is the width is the big factor that affects the geometry and the reason why they're different.
I had a bit of concern as I am lacing my 19" Dyna hub to a 21" Sportster rim and spokes. The part numbers for the DYna and XL 19" rim and spokes are the same...so I assumed the 21" would work well...then I noticed the spoke hole pattern. Though, quite a few of the 21" rims at JP Cycles with a similar hub, have the regular holes as on the 19" (not staggered). So was the staggering really necessary?
