nightster rear lights
Old 12-04-2010 | 03:03 PM
cjbmustang's Avatar
cjbmustang
Default nightster rear lights
Anyone have a part # for nightster all-in-one turn signal/brake/running lights?
Thanks,
Chris
Old 12-04-2010 | 03:44 PM
HOTLAP's Avatar
HOTLAP
Old 12-04-2010 | 08:19 PM
cjbmustang's Avatar
cjbmustang
looking for the black turn signals that come stock on the nightsters...a search turned up nothing
Old 12-05-2010 | 12:05 PM
cjbmustang's Avatar
cjbmustang
bump...still can't find part #
Old 12-06-2010 | 11:57 PM
DeD Fred's Avatar
DeD Fred
You also need the box under the seat if you are converting from a two wire system.
I used nightster take off parts to convert my "C" to a bobbed rear.
If you just need a replacement, the stealer will gladly give you the number
Old 12-07-2010 | 08:02 PM
cjbmustang's Avatar
cjbmustang
i emailed the dealer i bought the bike from and haven't heard back yet. i also searched ebay and used google, not to mention the classifieds here and have come up empty handed. looks like the previous owner dropped the bike as both rear turn signals, along with the tail lamp have some nice scratches on them. painting is out of the question
Old 12-08-2010 | 12:05 AM
mreed's Avatar
mreed
You can use any 3 wire front (stock) signal and paint or powdercoat them black. The "all-in-one" deal doesn't have anything to do with the lights themselves. BUT the threads are different so you'll need to figure that out.
OR, if all you're concerned about is the appearance, you can get any similar looking Sportster rear turn signal housing and simply transplant your "guts" into it...and paint or powdercoat them black of course.
Old 12-08-2010 | 10:18 PM
cjbmustang's Avatar
cjbmustang
i chopped the rear fender and eliminated the brake/run light. i will probably use the badlands setup for the brake/turn/run. my turn signals are gouged right on the sides so they are very noticable
Old 12-08-2010 | 10:46 PM
mreed's Avatar
mreed
If you're using the badlands unit (or the HD unit for that matter) you don't want Nightster lights. You'll need plain old 2 wire Sportster rear turn signals...and a pair of red lenses. With the module you're talking about the 2 wire turn signals will operate exactly like the Nightsters do.
Old 12-09-2010 | 06:13 PM
cjbmustang's Avatar
cjbmustang
So if i'm using nightster tail lights I dont need the box, correct? Is it just cut and splice?
Would I still need a load equalizer?
Sorry, still learning...
Thanks,
Chris
edit: dealer came through with part numbers, but still need an answer to the above
