04-up Sportster oil cooler. FEEDBACK?
Old 11-25-2010 | 10:42 AM
streetfighter06's Avatar
streetfighter06
Default 04-up Sportster oil cooler. FEEDBACK?
http://cgi.ebay.com/ebaymotors/HARLE...Q5fAccessories
Been contemplating this for a while. It looks like the same cooler that comes on the XR's. Awesome side-mount!
2 questions....
Anyone got one or pics of it mounted?
Does it actually help lower the oil temp?
I mainly want it for asthetics. I love the way it looks! Thoughts?
Old 11-25-2010 | 06:27 PM
Osco's Avatar
Osco
Account Deactivated
Will drop Oil Temps 15-20 degree's,,while yer movin,,
Might be a good Idea for HOT climates,,
Harleys are designed to run about 230 degrees,,
Most guys I know with Oil tank temp guages get
about 200- 220 with synthetic oil.
Oil needs to reach 212 for a time to burn off condensation,,,
I'm In Florida,,It's on my list but not a priority..
Looks cool,,I want one,,,
BUT,,only time I have heat issues Is in Rally parades,,
It won't do much for that,,,
For cooler days ya can always make a nice leather cover for it XD
1st pic has one,,notice the second pic,,no coolers,,
They took em off cause they know the engine performs better at spec temps..
an they always got air flow,,,
Attached Thumbnails 04-up Sportster oil cooler. FEEDBACK?-bm20100610_action1.jpg   04-up Sportster oil cooler. FEEDBACK?-xr1200-race-m.jpg
Old 11-25-2010 | 07:03 PM
streetfighter06
I'm in Texas.
Thanks, OSCO!
Old 11-26-2010 | 12:32 PM
bmorebhoy's Avatar
bmorebhoy
I've heard the Harley coolers are all made by JAG. I have an H-D cooler on my RKC and a side mount JAG on my XL. They do help, I live in NYC and traffic is bad and slow so the coolers help. The JAG on the Sporty has a dial in the middle of the two hoses just below the cooler body where I can run the oil through the cooler or divert through the dial to just go back to the filter. It helps in the winter.
Old 11-26-2010 | 09:55 PM
old skool1983's Avatar
old skool1983
Livin in FLA, got a JAGG on mine, this is a can of worms your opening up. All I can say is that my bike used to overheat and shut off every year I went to bike week. After I installed my oil cooler it has never happened again
Old 11-27-2010 | 03:57 AM
mparrish2010's Avatar
mparrish2010
i put a oil cooler on my 2010 forty eight!
Old 11-27-2010 | 04:02 AM
mparrish2010
Default oil cooler pic
heres another pic!
Old 11-27-2010 | 06:35 AM
Osco's Avatar
Osco
Account Deactivated
Well You just convinced me,,
At Leesburg I got stuck In the Parare crawl,,got er hot.
If the cooler helps In that slow crawl It must be the extra surface area.
Gonna have It,
A Jag I saw in J&P cycles looked a bit narrower than the factory HD one,,
Old 11-27-2010 | 09:11 AM
jkinner's Avatar
jkinner
I put the HD on my 1200L(09) definatly helped if not for just the little extra oil in the
system. Simple install but try to time it with your next oil change. I average between 200-215F. (synthetic)
Old 11-27-2010 | 01:51 PM
old skool1983
Gonna have It,
just for the sake of ease, I would suggest getting an adaptor with it...it turns the job into a bolt on job that you can do with an oil change...it costs a little more but no re-routing of oil lines.
Quick Reply: 04-up Sportster oil cooler. FEEDBACK?
