How to Install Clip Ons on 2010 Iron
Thanks guys! I did pick up the manual (you can actually download it for 6 bucks instead of buying it for $60) so I have all of the torque specs. Hopefully I'll post some pics tomorrow and let you know how it went. I would have ended up taking the bike apart just to install them if I didnt ask here first lol
2010 Sportster Manual PDF Download - $5.99 http://www.tradebit.com/filedetail.p...e-manual-xl-xr Thanks again for the tips guys, I'm starting the project now. Should have pics tonight.
Pictures today might have been a little ambitious
Thanks to the advice here the clip ons went on in a snap. I had a friend of mine give me a hand (hats off to anyone who did this alone). Loosened the pinch bolts, raised the bike on the lift with the front tire on and the forks slid right out. Put the clips on, had him hold the forks in line and lowered the bike to get the forks back in place. Took 5 minutes. Thought I was home free
The problem came when I tried transferring the stock controls to the clips. The front brake line (running to the steel mounted line) is way too tight and the clips dont have indents for the stock wiring. So I'm going to assume anyone running these clips changed the front brake cable and wired the stock controls internally??
Can anyone recommend how to mount the stock brake line or point me to one I can buy?
![Frown](https://www.hdforums.com/forum/images/smilies/frown.gif)
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
John - Bite the bullet and do internal wiring - like I recommended in an early post. Otherwise you will just end up with problems down the road like I did if you try taking a shortcut.
As for the brake line - yes, it's very tight! It will stretch to accomodate the bars IF they hug the bottom of the TOP tree. I ran mine like that for a while with no issues.
Here is the link to a thread I made a few weeks ago when I decided to SLAM my bars. The brake hose was an issue, so I disconnected it at the top tree, bent the brake line with a tubing bender and re-routed my line up the right fork tube. Or you could buy a new line, I guess. I like 'making' rather than 'buying'. Read on....
https://www.hdforums.com/forum/sport...headlight.html
Well I ended up scrapping the cheap ebay clip ons I started out with and went with RSD Clip Ons. The difference in quality is night and day. They were easier to install as well since they have dimples for the wiring.
I cant figure out how you guys get the front brake line to fit. Mine isn't tight, it's just WAY to short to even attempt screwing it into place. So I'm gonna tie the line up and bring it to a bike mechanic I know to install a new front brake line.
The clip ons look GREAT, only problem is now the speedo looks horrible up there in the middle of nowhere. The dummy lights for the RSD mount will be available on the 8th, so in a couple of weeks this project should be finished.
Thanks again for the help guys.
I did, but I really don't like the look of the bent brake line, and wiring the handlebars internally was more trouble then it was worth. If I get another set of bars down the line I may not want them wired that way and would have to redo all the lines again. Compared to the RSD clips the ebay ones felt like a joke. Plus they are already power coated black matching the top tree, looks great. Painting the ebay clips would have just chipped over time and looked like crap. Install of RSD's was a snap.
