Question about Screaming Eagle mufflers
Old 10-30-2010 | 06:19 AM
mreed's Avatar
mreed
You may be running a bit lean too. You can check your plugs. If they're white-ish you need more fuel.
It could also be an exhaust leak...but I would wager you have a leaning issue. Can you see how bad the pipes are discolored under the heat shields?
Old 10-30-2010 | 06:25 AM
Guest
Guest
Posts: n/a
It almost sounds like you have two different things going on: decel pops (burble, burble, pop, pop, pop, burble) and backfires (burble, BANG, burble). If so, sealing the exhaust can help (and might cure) the backfire, and might help the decel pops, even though they're normal. If sealing the exhaust doesn't cure the issue, talk to a competent mechanic about a tune-up or other possible issues.
Old 10-30-2010 | 07:54 AM
Brion B's Avatar
Brion B
No discoloration under the heat shields but header bolts were a bit loose.Also noticed some soot from front header clamp being loose.This should solve the problem.Thanks guys.
Old 10-30-2010 | 08:11 AM
Guest
Guest
Posts: n/a
Cool. Try it out, and let us know.
Old 10-30-2010 | 09:38 AM
1200Cdriver's Avatar
1200Cdriver
My exhaust nuts have come loose twice so I ordered aircraft nuts and am waitiing for ScreamingEagle exhaust gaskets to arrive.
Attached Thumbnails Question about Screaming Eagle mufflers-bagger-small-.jpg
Old 10-30-2010 | 11:16 AM
ranger50's Avatar
ranger50
I have Screaming Eagle II mufflers on my 883. I have definitly noticed a rise in power. I have not had the problem of backfireing,poping, or any of that stuff. And, Mine is an 02 with a carb., No EFI.
My Brother's Streetbob is EFI, and his bike is always backfireing, coughing, and snorting. This happens mostly when he starts the bike.
Old 10-30-2010 | 03:59 PM
Brion B's Avatar
Brion B
I have rode the bike after tightening the header nuts and installing new spark plugs(old plugs still looked new with 4500 miles) and a lot of the popping is gone,but not all.Seems to run just fine though.Actually the plugs are white as if still new with no buildup or discoloration,maybe it is running too lean after all?
Old 10-30-2010 | 04:34 PM
deepsea's Avatar
deepsea
Ditch the SE II baffles and get thunder city monster baffles. You will love them.
Old 10-31-2010 | 11:14 AM
exemexer's Avatar
exemexer
Yes white is too lean, plugs should be kinda chocolate brown - but not black at all.
Old 10-31-2010 | 12:22 PM
Brion B's Avatar
Brion B
Okay,how do I correct the problem of it running too lean?
Quick Reply: Question about Screaming Eagle mufflers
