What oil filter do you use?
1 Post
I have used Fram as well, but after reading all the problems I won't again. Problem is, selection around this hick town is very limited. I now use HD filter because it is actually available here. My indy sells it for about the same price as a Fram anyway, and it does seem to work longer before the oil gets dirty looking.
Here's what I use.
http://www.gopurepower.com/store/ite...em&itemKey=684
Just be careful what you use. The Sporty oil system is based more on volume than pressure. According to my manual, it's 12 to 14 psi. So don't run too restrictive a media or you will be starving it for oil. 30 micron is what they spec I believe.
What benefits can you tell from running the bigger filter with more oil?
- Extra exterior surface area provides a bit more cooling.
- 50% more filter media means less chance of the filter becoming clogged between oil changes.
- If your like me and punch holes in the end of the filter to drain it before removing during an oil change, the longer filter gets the end of the filter out further from the bike frame and that means less oil drip mess on the bike frame and front motor mount. (oil on the rubber motor mount is not a good thing)
- About 4oz extra.
