Compesator sprocket
Old 10-15-2010 | 08:26 AM
WRAITH's Avatar
WRAITH
Default Compesator sprocket
How do you know when it's time to replace a compensator sprocket? There seams to be a lot of free play in my drive line. With the bike in 1st you can roll it about 6 inches before it stops. I'm replacing the clutch this week end and thought I should check while the primary's open.
Old 10-16-2010 | 08:10 AM
WRAITH's Avatar
WRAITH
Has any one had to replace the compensator sprocket?
Old 10-16-2010 | 10:51 AM
Gpsjr10's Avatar
Gpsjr10
What exactly are you calling the compensator sproket? If you are talking about the primary chain tensioner, it is a nylon shoe, not a sproket.
Old 10-16-2010 | 01:20 PM
HOTLAP's Avatar
HOTLAP
If it is the tensioner shoe your talking about its time to replace it when you can no longer adjust the primary to spec.
With your high mileage I would say it would be a good idea to change it while your in there anyway.
Old 10-17-2010 | 10:41 AM
WRAITH's Avatar
WRAITH
The compensator sprocket is primary drive sprocket. It is designed, to allow some free play in the primary chain during acceleration.
Old 10-17-2010 | 06:16 PM
Gpsjr10's Avatar
Gpsjr10
I'll have to check that out, I thought it was just a solid sproket. Does it slip or is it spring loaded? How does it work?
edit: Google is my friend!
Old 10-18-2010 | 12:48 PM
WRAITH's Avatar
WRAITH
I removed the primary cover and discovered that there is a solid drive sprocket. Turns out that only big twins have compensator sprockets.
sandlug
13
02-25-2017 05:38 PM
stephtell
EVO
04-20-2016 07:28 PM
61flh
EVO
01-07-2014 09:55 PM
grounded7
Shovelhead
06-06-2008 09:29 AM
gsparesa
06-06-2006 05:22 PM
