2003 Sporster XL1200 - Jerking and Slipping
I took my ol' lady's Sportster out today and noticed that it acts funny when stopping/starting. When you go to take off, it seems like the primary hits the compensator nut hard; a sudden drive-train shock. Then moves and run fine. Once you stop again, you let the clutch out slowly and "crack" ...then movement. Nothing when you're up/down shifting.
I have checked the tension and it appears fine - unless there's suppose to be an unnatural level of tension that I am not aware of.
Now, the other funny thing is when taking a hard left turn (lean) at low speeds, it feels like it does the same thing, but no power like the gas cuts out....I suspect they are related, but I am lost where to start troubleshooting.
Any ideas?
Any ideas?
I was thinking possibly clutch, but 8,000 miles sound very early even for the poorly designed clutch on the Sporty. Nonetheless, this thread might provide some useful info.
https://www.hdforums.com/forum/sport...tch-alert.html
Any ideas?
Any ideas?
Just so you know.....Sportsters do not have a compensator nut.
Plus they love and need more RPMs when starting off or going slow than the BT's. If not they buck like a bronco. More R's and a little clutch slipping at slower speeds will probably solve your problem.
