Problem with slip on exhausts?
10-02-2010, 05:36 PM
The solution is obvious. Your bike is in serious need of a new shop. I hope the next one is not too far. Forget slipping off the mufflers. Slip right out of your old garage into a new one.
10-02-2010, 06:14 PM
You know I really confused now!!!!! I just read that pipes of 2" dont need the EFI remapped and over that they do!!!!
I tell you if the bike over heats with the stock pipes back and new seal there'll be war :-)
N
01-14-2011, 08:17 PM
01-14-2011, 08:34 PM
you said something about the heavy breather ? was it installed when this happen ??
01-15-2011, 01:59 AM
THEY ARE LYING TO YOU.
I have rush 1.75s and even before the SE A/C and nightrider 14.0 XiEDs, it ran just fine.
Go to the nightrider site listed above and read the truth about closed O2 systems.
01-15-2011, 02:41 AM
Quote:
Originally Posted by
DeD Fred
Not to derail or anything, but your sig pic is hot. The spelling; not so much.
01-21-2011, 11:06 AM
flat4fan
It was removed, so its not hot no mo.
I concur, you need to find another dealer.
When I had just the rushes on, it did not pop. After I added the X14Ieds, and SE A/C, now it pops a little . Its no biggie, I can live with it.
Rick71
05-29-2018 12:11 PM
Switcharoo
09-18-2013 09:06 PM
K9Tamer
08-07-2012 04:40 AM
ash uk streetbob
05-14-2012 06:19 PM
speckfisher
10-26-2008 11:11 AM
1200 ,
bike ,
causing ,
eagle ,
exhausts ,
fitting ,
flow ,
free ,
lean ,
ons ,
run ,
screaming ,
slip ,
sportster
