Guys is there a rear fender romoval "how to" guide? I take the 2 screws out of the top of the fender, then the screws on the inside tail end, then took off the seat and unscrewed that thing... what's left?
On my 883C I removed the turn signals that were bolted onto the struts, then four (two on each side) nuts/bots on either side of the fender, then there was one bolt right underneath where the seat is right in the middle of the fender. Once those bolts were loose the fender was loose and I just lifted it straight up and out.
Some advice, get the service manual, it'll save you a lot of headaches in the future. It has an expanded view of the fender that makes it easy to see all the fasteners.
